What you will find
Below you will find many of the tools, supplies and materials that I use everyday for my installations. Some of the tools that you see me using in my videos are no longer made. I have posted other tools in there place that I have used and found to be reasonably priced and high in quality.
I do want to inform you that these are affiliate links that I make a commission from. If you decide you want to use these links, my family and I want to thank you!
I only recommend tools that I would use myself and they must be of high quality!!!
The ULTIMATE Bootcamp Bundle
Get Help with your project using Plank Bootcamp and Use The Perfect Tool Set to get the project done!
The Plank Hammer
This is Perfect Tapping Block for ALL Skill Levels and it fits any size hand.
Here’s what I have been looking for in a Tapping Block –
- It needed to be made tough to handle Brute Force when needed.
- I also wanted to be able to use it with gentleness.
- It had to be easier to use than the other tapping blocks on the market.
The Plank Hammer is designed to be less bulky and much easier to handle. You can be very Delicate with it or you can use Brute Force when you need it.
The Handle was MOST Important
The Plank Hammer allows you to get a grip in multiple positions on the handle. It allows you to be more Precise and/or to use Finesse when Tapping planks together.
The handle design makes it Easy to grip and even the smallest hands are able to use this without struggle.
Because this is so easy to use, most of you will perfect it quickly!
And, you will be able to –
- Get the Plank together easier. The Plank Hammer makes it EASIER to get even the most stubborn Planks together.
- Avoid causing damage to the Planks Locking System while tapping directly on it. This saves time from having to use a scrap piece to protect the edge before tapping.
It is very Simple to use and even the least experienced DIY’er will get the feel of it very quickly.
I have been using this Tapping Block for awhile now and I absolutely love it!
Joe Letendre
The Tapping Block and Pull Bar are NOT the tools to cheap out on. You will regret it if you do.
I am also gonna give you FREE SHIPPING
The Plank Puller
This is Perfect Pull Bar for ALL Plank – Vinyl Plank, Laminate and Wood.
Here’s what I have been looking for in a Pull Bar –
- I also wanted more room to swing my Dead Blow Hammer(so I don’t damage a wall)
- It had to be BETTER than the other pull bars on the market.
The Plank Puller is designed to be SUPER TOUGH and much easier to use. Because it weighs 4lbs. it does most of the work for you.
You don’t need to swing the Hammer as hard to get the Plank Puller to do its job.
The working room was MOST Important
There is 13 1/4 in. from the Knuckle of the Plank Puller to the Wall!
The Plank Puller allows you to have more room when swinging the Dead Blow Hammer. This is really important because you get more leverage and you can deliver stronger blows.
Which means – The Plank will go together EASIER.
Plank can be stubborn when installing along walls and tight areas. The extra room you have from the Knuckle of the Plank Puller to the Wall is very crucial.
The EASIER it is for you to swing your dead blow hammer, the stronger blow you will be able to deliver. This makes installing Plank much EASIER.
I have been using the Plank Puller for awhile now and I absolutely love it!
Joe Letendre
Spacers
I have never been a fan of spacers, until now. These spacers are very easy to use and they ACTUALLY WORK! Watch the video above and you can see for yourself how these will help you with your Plank installation.
Dead Blow Hammer
This is the dead blow hammer you see me use in my videos. I use this because I also install wood floors, so it is a great multi purpose hammer for me. The caps are replaceable and this thing works!
Dead Blow Hammer
This is a decent Dead Blow Hammer set. It is not as good as the one I use in my videos, but it comes with 2 hammers and it will definetly get the job done.
You really cannot beat the price on these Dead Blow Hammers and I think they are very solid!
Pro Knees
By far these are the best knee pads on the market. They are very comfortable with the foam that is an inch thick. The straps do not dig into the back of your legs and are very easy to connect. These will last forever and I use them at home and work!
Quiet Walk for Vinyl Plank
This pad is complete with a sound barrier, vapor barrier and it is resists mold and mildew with its Anti Microbial Treatment. It is EASY to install and feels great under your feet. It is the thinner version of Quiet Walk and is good to use under ALL LVP.
Quiet Walk for Laminate
This pad is complete with a sound barrier, vapor barrier and it is resists mold and mildew with its Anti Microbial Treatment. It is EASY to install and feels great under your feet. It is the thicker version of Quiet Walk Pad meant for Laminate.
Fasten Master Glue Gun
This is the Glue Gun I use to attach transitions to the floor. I use it to glue scrap pieces down to secure the floor in a plank installation. I use it to attatch wood planks to the floor under cabinets, along walls where the nail gun cannot reach. This can also be used for so many things other than flooring.
Adtec Glue Gun
This is a alternative to the Fasten Master Glue Gun. It works well with the Fasten Master Glue sticks. I have tested this glue gun and I find it to be a good glue gun that has done what I have asked of it. I do feel my Fasten Master is a bit better and I would recommend that over this if you are a Pro.
Fasten Master Glue Sticks
These are not the glue sticks that you buy at Walmart or any of the Big Box Stores for that matter. I use these to install transitions, for gluing scrap pieces down when securing the floor on concrete and for a variety of other things. These are amazing!!
They are meant to stick to the concrete and to the vinyl plank and are a great alternative to using a hammer drill.
Masterweld 948
This is the adhesive I use for setting transitions. It is a superior adhesive with great holding power and it dries very quickly. It adheres well to plastic, concrete and wood.
Plank Bootcamp
Join the thousands who were able to Install their own Plank Using Plank Bootcamp.
Using Plank Bootcamp you’ll know how to choose the BEST Plank Direction, how to decide where you should start and be able to find EASY to Master Installation methods for your Plank Project.
I wanted this to be SIMPLE and for any skill level! That’s why I created The Plank Bootcamp Guide, which is only found inside Plank Bootcamp.
I also wanted to make this Affordable for all of my supporters.
This Plank has taken the crown from Mannington
Flooret Modin Signature is one of my favorite Brands of Vinyl Plank. This plank is very durable, easy to install and looks stunning.
I also LOVE the price point on this plank! No other Comparable Plank is even close to the price point of this Plank.
They also have a bargain on their Modin Base and that plank still has a 20 mil wear layer.
Check it out for yourself and watch my review video. You can also learn how to get discounted samples.
Wood that Performs like Vinyl Plank
Flooret Silvan is an incredibly durable Wood Plank. I tested this product and to honest, I was not expecting it to be anything special. Just another Engineered Wood on the market. I was WRONG!
This wood floor is going to give Vinyl Plank a run for the title. It has a super strong core, it’s topically water proof and the Acrylic protective layer is extremely scratch resistent.
I have NEVER seen a floor install easier than this and I believe there is no other plank on the market today that is this DIY Friendly!
Watch my review video and also learn how you can get discounted samples.
Plank Cutter
Free Shipping in the USA – Watch the video below
13.5 inch Cutter that cuts Vinyl Plank, LVT, Laminate and Engineered Wood up to 1/2 inch thick.
I spent a lot of time finding the BEST Plank Cutter. One that I could proudly recommend to my friends.
Here were my must haves –
- It needed to be made tough.
- I also needed it to cut through the thickest Plank.
- It needed to be easy to use.
This Plank Cutter is designed to be EASY to use, built tough and it’s Affordable.
Convenience and EASY Precise Cutting was MOST Important to me.
This cutter is very simple to use and it has a lot of cutting POWER. It is also very precise and makes really nice, clean cuts.
It Also makes angled cuts
Time, Bad Knees and a Sore Back
Having a Plank Cutter next to you during your Install SAVES you a Ton of Time. You don’t have to go outside to make cuts.
You Will SAVE HOURS on your install, that’s why the Pro’s Use It!
Getting up and down constantly is very hard on your back and your knees.
- You Don’t have to get up to make cuts.
- It’s Dust Free Cutting! No Worries about causing a mess when cutting in the house!
AND….Because this is so easy to use, you will perfect it quickly!
I have been using this Plank Cutter for awhile now and I absolutely love it!
Joe Letendre
Shark Knife
I have been using this Utility Knife for years and I absolutely love it. It is very durable, blades are easy to change, it holds 10 blades and it fits in the hand very well.
Linoleum Knife/AKA -Tuck Knife
This is the best multi purpose tool you will ever own! Your welcome!! I use this tool for almost anything. If you have watched my videos, I am sure you seen me use it!
CLC Tool Pouch
This is the tool pouch I use. It fits on your side easily and can carry multiple tools. I mainly keep my utility knife, tuck knife, marker and pen in there. You can also hang your tape measure from the clip.
Oscillating tool Blades
These blades come in a 24 pack and are packaged in a convient plastic tube. These type of blades are crazy expensive in the big box stores. These blades are just as good, if not better than the blades found at the big bo stores.
Ardex Feather Finish
This is the only Floor Patch I use and it NEVER fails me. I do use modified thin set for deep filling and then this to finish it off.
Henry's 549
This is made by Ardex, but I am not completly convinced it is the same as Ardex Feather Finish. This also sold at Lowe’s and Home Depot.
Blades for jigsaw
This blade will cut through even the toughest Vinyl Plank. You can use standard Jigsaw Blades for most WPC but, this blade will cut through WPC and SPC.
The blade lasts a long time! I would buy 2 and you should be good for the entire job.
Small Plane Tool
THIS DOES NOT WORK ON MOST VINYL PLANK, but works on all Laminate.
Use a sharp chisel for vinyl plank.
This is the tool that I use to cut the lip off the groove. It allows the joints to slide together easily. I use this method in areas where it is hard to get the planks together.
Trim Removal Tool
This tool works very well for taking off wall base. It helps prevent damage to walls and to the base itself.
This is a specialty tool and you could probably get away without it. However, it is pretty amazing and usefull and that is why I had to share it.
Stair Step Scriber
This is a tool that will help you get perfect measurements when installing Vinyl Plank, wood or laminate on stairs.
I know some of you are not Milwaukee fans! That is why I want to introduce you to Acme Tools. These guys carry EVERYTHING! And I mean every brand and every tool that brand has. They are my go to store for all my power tools.
Check them out here –
I bought this packout and really was not sure what to expect. I really wanted an easier system then what I was using so I gave it a try.
Within a week I was back at the store buying another complete packout, along with a couple other packout attachments for screws, nails and a lot of my other misc. items.
THIS THING IS TOUGH!
I have made my life so much easier now that I have it. switching out tools from my truck to the shop is quick and very organized.
The wheels are very ridgid and have survived 4 Northern Minnesota Winters so far. I really could not be more pleased.
About 2 years ago my son added this to our trailer. We needed something to keep our drills, drill bits, screw tips, batteries and charger in. Something easy to grab and bring into the job.
I kinda laughed at him for buying it cause it’s a backpack. How long could this thing possibly last? Well, it has been 2 years now and we use this thing everyday. The Zippers are still strong as ever and there is not one rip or tear in this thing.
This backpack is really tough and I really like how handy it is to have.
We always carry 2 drills in this(an impact and a hammer drill) along with 2 or 3 five amp batteries and a fast charger. Along with jigsaw blades, a box for screw tips and 2 boxes of drill bits.
This is the impact screw gun I use and I like it! It has a ton of power and I really like the adjusting speeds it has.
I really have put this tool to the test and it has lasted me a long time. I screw down a lot of subfloor on my jobs and I also install a lot of cement board and this tool has never overheated on me.
I have never smelt any burning in the motor or have had any problems with the trigger.
It is an all around great tool.
Very nice tool to have. I have had to cut a thousand door jambs with this tool and it keeps on ticking.
It is easy to change blades without any tools and I have never overheated this tool. Believe me, I have definetely put it to the test where I feel it should have overheated.
It has multiple speeds that you can choose from just by spinning the dial on the side.
This is a hammer drill/driving drill/drilling.
It works very well and is overall a great drill. The hammer selection gets the job done however, if you have a lot of drilling to do then you might want to consider a hammer drill that is corded.
This drill works well for hammering, it just does not quite do it quite as fast as I would like.
I do use the hammer mode alot and have never had any issue with it. It is nice to have in the arsenal of tools because of the convience of the battery.
Most of my tools are battery now andit really is nice to pull this out for the need to drill a few holes.
WOW!!! Now this is a great light to have! I use this at work, home, camping, hunting camp, working on the car…..
It is super bright and it is very convienent.
I have two of these and they both get a lot of use.
This light can be used with battery or with a cord and does NOT charge the battery when it has a cord attatched. They do sell one now that does charge the battery but, I really did not see the need to pay the extra money for that feature.
I usually use this light in situations that a cord is not used.
This is the jigsaw I have been using for almost two years now. It has been another good tool that I can’t complain about at all.
It has a quick changing blade and also variable speeds.
It also has other adjustments to cut different angles.
