A Simple Measuring Method
If you haven’t installed much tile , well than just thinking about how to measure for tile cuts can seem to be a difficult and frustrating task. But it doesn’t have to be.
There are a few ways to do this, let me show in the video below just how easy this actually is using my method.
Once you decide how big of a grout joint you want, then the formula for measuring is as simple as this – one tile + the grout joint + 1/8 of an inch = ?
That’s it ! It’s really that simple when use a grid system.
Just check out this video on how to measure for tile cuts.
With a few simple measurements and a chalk line, I was able to create the grid. Once the grid is done and I put it to use, it’s almost like I’m cheating.
There are so many benefits to using a grid and this is just the icing on the cake. Let me show you another video, where you will see how to measure for tile cuts around a door jamb
You see, when I show you how to measure for tile cuts, it doesn’t have to be hard. As you seen in the last two videos, it really is simple. I like to use this method when I am measuring for tile cuts for a few reasons, here they are-
It’s Error Proof-
When using my method on how to measure for tile cuts, you will not have miss-cuts. It really takes the stress away of trying to figure out the tile cuts.
You get the exact measurement you need!
There’s only one measurement –
Once I figured out how big my tile was plus the grout joint, then I just added the 1/8 of an inch for the gap between the tile and the wall. That’s it!
I did have one area at the door where I didn’t need the 1/8 of an inch gap, so I eliminated it.
If you want to really keep it simple , then don’t eliminate it. Just use the same number all throughout the installation.
It’s just plain FASTER-
When I first started installing tile I didn’t use this method. Well the truth is, I didn’t know it. After many times of failing, when I tried to measure for a cut and then transfer it onto a tile, I tried this method.
It was really a struggle for me before I used this method. I would miss-cut tile all the time. Take a look at look at a tape measure and try to figure out what the measurement should be after subtracting 3/8 of an inch.
You see what I mean- what a pain in the butt!
The Final result is a better looking tile installation!
If you are not sure how to make the grid system on the the floor, that’s okay. I can show you how to design a tile layout, just click on the button below to check out my post – How to Install Floor Tile the Easy Way.
I also would like to share other tips with you. Many of the tips that I share are exclusive to either subscribers of my Tips and Guides or members of Tile University-
Joe
Christ is our Savior!
