Building a shower pan can sound hard, but it’s not!
If you have the right tools and guidance for the job it sure does make things a lot easier.
The tools and supplies that you need are not expensive and you probably have most of them.
Here is a list of what you need-
- level
- tape measure
- screw gun or drill
- shovel or a hoe
- mud pan or a wheel barrel or a few buckets
- 2 to 3 2 X 4’s
- sand mix
- magnesium concrete trowel($20 to $30)
- squirt bottle
- 2 1/2 inch screws
Now that you know what you need for tools, let me show you an error proof method that is also by far the easiest method to building a shower pan.
In the videos below, you will learn how to build a pan and have the confidence to do it! From Step 1 to You’re done I will guide you!
This is MEMBERS ONLY CONTENT. If you are interested in becoming a member, click the button below!
Click Here for Building a shower pan
