laminate Installation-cutting laminate flooring around a doorjamb
In this post I will explain how to mark a laminate plank and how easy it can be cutting laminate flooring around a doorjamb. I will show you a few great tips that you can use to do this. They will quite simply blow your mind. I use such an easy method here that you will be thinking , you can’t believe you didn’t think of it yourself.
Laminate installation- making a cheater board
The first thing you will need is cheater board. You will need this cheater board throughout your entire laminate installation. You need to cut a scrap of laminate about a foot long. Then you will trim off the female edge. The female edge is also known as the groove that receives the tongue or the male end. Here is a picture of the different ends.
Laminate installation- marking the doorjamb
You are going to need to watch the next instructions on cutting laminate flooring around a doorjamb. Its just easier to see than to just read so here is the video.
Comments are always nice to have and are much appreciated!
They also help my google rankings so please leave a comment. I have a lot more videos and posts on how to install laminate flooring, so check them out! more laminate videos Joe Letendre Spend time with God. He loves you and He misses you!
