Building a Custom Shower Pan
These videos are in order of the steps that you should take while building a shower pan. You must install cement board on the shower walls before building the shower pan.
What Type of Drain Should be Installed?
 How to Mark the Location of the Curb
Building the Curb
Marking where the Pan Ends
Mixing Sand Mix
Building the Pan
Submit a Comment
Your email address will not be published. Required fields are marked *
This site uses Akismet to reduce spam. Learn how your comment data is processed.
