The Plank Puller
Original price was: $59.99.Current price is: $49.99.
Thank you for your business, my family and I really appreciate you!
SKU: sthydt0010 Categories: ,
This is Perfect Pull Bar for ALL Plank - Vinyl Plank, Laminate and Wood.
Here's what I have been looking for in a Pull Bar -
    1. It needed to be made tough to handle Brute Force when needed.
    2. I also wanted more room to swing my Dead Blow Hammer(so I don't damage a wall)
    3. It had to be BETTER than the other pull bars on the market.
The Plank Puller is designed to be SUPER TOUGH and much easier to use. Because it weighs 4lbs. it does most of the work for you.
You don't need to swing the Hammer as hard to get the Plank Puller to do its job.
The working room was MOST Important
There is 13 1/4 in. from the Knuckle of the Plank Puller to the Wall!
The Plank Puller allows you to have more room when swinging the Dead Blow Hammer. This is really important because you get more leverage and you can deliver stronger blows.
Which means - The Plank will go together EASIER.
Plank can be stubborn when installing along walls and tight areas. The extra room you have from the Knuckle of the Plank Puller to the Wall is very crucial.
The EASIER it is for you to swing your dead blow hammer, the stronger blow you will be able to deliver. This makes installing Plank much EASIER.
It is very Simple to use and even the least experienced DIY'er will get the feel of it very quickly.
I have been using the Plank Puller for awhile now and I absolutely love it!
Joe Letendre
The Tapping Block and Pull Bar are NOT the tools to cheap out on. You will regret it if you do.
Additional information
Weight 76 oz
Dimensions 20.25 × 5.5 × 5.75 in
Reviews
There are no reviews yet.
Be the first to review “The Plank Puller”
Your email address will not be published. Required fields are marked *
This site uses Akismet to reduce spam. Learn how your comment data is processed.
Learn From Joe and Find EVERYTHING you need to Complete Your PLank Project.
PLUS- Get Exclusive One On One Coaching with Joe
What do I get with PB?
Q
Get Plank Bootcamp, The Plank Hammer, The Plank Puller-everything you need for your Plank Install – Joe’s way. PLUS- Exclusive One on One Coaching with Joe.
What do I get with PB Bundle?
Q
The Proven System that Works.
Choosing the Best Plank Direction
I decide Plank direction using 3 Key Factors. Lighting and Joist direction are not on this list.
However, the condition of the floor over rules all 3 of these key factors and using Joe’s guidance can save you money, time and frustration.
Joe will share the pros and cons of each direction and help you make the best choice for your situation.
Find the Best Place to Start
I don’t just start anywhere. There are several things I take into consideration to help me decide where the best place to start is.
DON’T Make Your Installation Harder.
The last thing I want to do is make the install harder because I started in the wrong place.
Joe will show you all of your options.
Get the Perfect Layout
Working with Joe and Using the Plank Bootcamp Guide, you will be able to get the best layout possible.
You will be able to use this guide for any size layout – one room or an entire house.
A good layout will also help you avoid difficult situations, transitions, small peices and the list goes on.
With Joe’s help, you will easily find the Best Layout for your project.
You will also find:
Staging your Project
Many of you will not be able to do your entire project all at once. This is where staging comes in handy.
Using a staging plan makes it so much easier for everyday living during your project.
Joe will help you make a good Plan so, you can do your project in stages.
This will help you Better Manage your project and to get it done with LESS STRESS!
    What Else is Included
    One Year access with 3 months of Coaching
    Plank Bootcamp-
    You may just be in the Planning stages of your project – No Worries, your membership lasts for an entire year, so you have plenty of time to access all of the Easy to Learn resources made available to you inside Plank Bootcamp.
    You also get Coaching Access to Joe for 3 months.
    Plank Bootcamp Bundle –you get access to Coaching from Joe for an entire year!
    When using the Plank Bootcamp Guide it will make your project easier and you will be able to get the job done faster.
    The Plank Bootcamp Guide brings you through each step of your installation. It can be used if you are installing one room or an entire house.
    In each step, I will coach you through your Plank Installation. This guide is so easy to follow and the steps are easy for anyone to use.
    You will save so much time knowing the proper steps to take during your installation.
    15 years. Thousands of Successful DIY'ers
    ” Love the university, extremely helpful!”
    Michael O’Sullivan
    “These videos are phenomenal. Thank you so much. God bless brother.”
    Joseph Underwood
    “Wowww! Awesome video! I’m in the middle of installing vinyl planks in my kitchen, and this literally just SAVED ME! Much, much easier than other videos I watched!! Very helpful! Thanks ????????”
    Nicole Kathlene
    “Dude, your videos are really helpful for an amateur like me. I can’t thank you enough!”
    Mity Eltu
    “Yay finally someone who does all the steps in a series rather than one off videos.”
    Connor Pearson
    “Wow. I am rarely moved to leave a comment, but thank you so much for sharing these practical tips. It makes what seemed like difficult issues seem simple. God bless”
    Zwingli Justice
    “yippie kyi yay i must offer my most sincere gratitude for your proficient efficient and generous bountiful fountain of experience, im ready now”
    Michael
    “I followed several of your videos. Super helpful. Installed into a large open area consisting of kitchen, dining room, hallway, and living room. First time installing flooring and while it took some time getting started, I nailed it. Looks great. Thank you.”
    Robert Evans
    “Awesome videos man! I feel like I’ve almost watched all your LVP install guides! Planning to buy your course to help support feature work :)”
    Jared Wins
    “I really appreciate all I have learned here!”
    Michelle Ragan
    “Thanks for the add. Seen your videos on YouTube and there very helpful. Decided its worth the money to become a member.
    I am a DIY’er good but not the best.????”
    Lonnie Berger
    “Joe,
    Thank you so much for all your videos. They have been extremely helpful in planning my laminate flooring install. ”
    Kent Grisemer
    “Almost done! Not a finished product vid, but I’m so excited about how the floor is coming together. It’s basically four rooms with a giant closet/wall/half kitchen island. Followed Joe Letendre’s advice and it came together perfectly!”
    Brad Palmore
    “Word of caution: If you do a good job on your floors you become the friend to call for other people’s floors as well. Thanks for the instructions Joe. They’ve come in handy more than I would have thought. Merry Christmas, may God bless you in this coming year.”
    Mike Feiock
    About Joe Letendre:
    Joe has been in the Flooring Business for over Three Decades as an installer, store owner and YouTuber. Vinyl Plank, Laminate, Wood, Carpet and Tile are the different types of flooring he is Specialized in. He and his wife Brenda have 10 kids of which most are grown, married and have kids of their own.
    He began helping DIY’ers 15 Years ago when he started his Online Presence and His Youtube Channel (So That’s How You Do That!) He has 240k+ followers on Youtube and has helped thousands of other people with their flooring projects.
    You can't afford NOT to do this.
    STOP wondering if you are capable of installing your own plank. Plank Bootcamp
    gives you everything you need to successfuly get your project DONE.
    Q
    Q
    One Quick Note
    I am really excited to begin working with you and to be a part of the project that you are working on.
    As a DIY’er and a professional installer, it always feels really good when a project is complete!
    I’ve always enjoyed to step back and look at what I have accomplished.
    I hope for you to have that same reward!!
