Plank Bootcamp Membership
Original price was: $199.99.$149.99Current price is: $149.99.
Perfect for any skill level
Why Use Plank Bootcamp?
Using Plank Bootcamp you’ll know how to choose the BEST Plank Direction, how to decide where you should start and be able to find EASY to Master Installation methods for your Plank Project.
You will be able to avoid getting stuck and not knowing what to do next.
You’ll be able to make a Proper Plan that is easy to follow and you will get your Project done FASTER!
Using Plank Bootcamp will help you get a Professional looking installation!
I also wanted this to be SIMPLE and for any skill level! That’s why I created The Plank Bootcamp Guide, which is only found inside Plank Bootcamp.
Learn From Joe and Find EVERYTHING you need to Complete Your PLank Project.
PLUS- Get Exclusive One On One Coaching with Joe
Get Plank Bootcamp, The Plank Hammer, The Plank Puller-everything you need for your Plank Install – Joe’s way. PLUS- Exclusive One on One Coaching with Joe.
The Proven System that Works.
Choosing the Best Plank Direction
I decide Plank direction using 3 Key Factors. Lighting and Joist direction are not on this list.
However, the condition of the floor over rules all 3 of these key factors and using Joe’s guidance can save you money, time and frustration.
Joe will share the pros and cons of each direction and help you make the best choice for your situation.
Find the Best Place to Start
I don’t just start anywhere. There are several things I take into consideration to help me decide where the best place to start is.
DON’T Make Your Installation Harder.
The last thing I want to do is make the install harder because I started in the wrong place.
Joe will show you all of your options.
Get the Perfect Layout
Working with Joe and Using the Plank Bootcamp Guide, you will be able to get the best layout possible.
You will be able to use this guide for any size layout – one room or an entire house.
A good layout will also help you avoid difficult situations, transitions, small peices and the list goes on.
With Joe’s help, you will easily find the Best Layout for your project.
You will also find:
Staging your Project
Many of you will not be able to do your entire project all at once. This is where staging comes in handy.
Using a staging plan makes it so much easier for everyday living during your project.
Joe will help you make a good Plan so, you can do your project in stages.
This will help you Better Manage your project and to get it done with LESS STRESS!
What Else is Included
One Year access with 3 months of Coaching
Plank Bootcamp-
You may just be in the Planning stages of your project – No Worries, your membership lasts for an entire year, so you have plenty of time to access all of the Easy to Learn resources made available to you inside Plank Bootcamp.
You also get Coaching Access to Joe for 3 months.
Plank Bootcamp Bundle –you get access to Coaching from Joe for an entire year!
When using the Plank Bootcamp Guide it will make your project easier and you will be able to get the job done faster.
The Plank Bootcamp Guide brings you through each step of your installation. It can be used if you are installing one room or an entire house.
In each step, I will coach you through your Plank Installation. This guide is so easy to follow and the steps are easy for anyone to use.
You will save so much time knowing the proper steps to take during your installation.
15 years. Thousands of Successful DIY'ers
About Joe Letendre:
Joe has been in the Flooring Business for over Three Decades as an installer, store owner and YouTuber. Vinyl Plank, Laminate, Wood, Carpet and Tile are the different types of flooring he is Specialized in. He and his wife Brenda have 10 kids of which most are grown, married and have kids of their own.
He began helping DIY’ers 15 Years ago when he started his Online Presence and His Youtube Channel (So That’s How You Do That!) He has 240k+ followers on Youtube and has helped thousands of other people with their flooring projects.
You can't afford NOT to do this.
STOP wondering if you are capable of installing your own plank. Plank Bootcamp
gives you everything you need to successfuly get your project DONE.
One Quick Note
I am really excited to begin working with you and to be a part of the project that you are working on.
As a DIY’er and a professional installer, it always feels really good when a project is complete!
I’ve always enjoyed to step back and look at what I have accomplished.
I hope for you to have that same reward!!
Reviews
There are no reviews yet.
